1993 Sportster - Which Ignition Switch For Tank Mount Dash?
Old 07-28-2008, 12:19 PM
KustimKool's Avatar
KustimKool
KustimKool is offline
Default 1993 Sportster - Which Ignition Switch For Tank Mount Dash?
Hey gang...I am revamping my 1993 XLH 1200. The fresher-upper includes a new sportbob gas tank with a tank mount dash setup. Of course this means that I will rquire a new ignition switch which is to be mounted in the dash on top of the tank. Obviously the original switch will not work for this application. I have tried two different ignition switches so far and neither of them work. Before I go and buy another on a whim, I need to know what WILL work. My system (if original) has three wires going to the ignition switch (red, white, green). SO my question is as follows :
For a 1993 Sportster XLH 1200, when using a sportbob tank with a tank mount dash - which ignition switch do I need? A supplier and a part number would be great!!
Thank you for ANY help!!
Cheers!!
Old 07-28-2008, 06:58 PM
KustimKool's Avatar
KustimKool
Default RE: 1993 Sportster - Which Ignition Switch For Tank Mount Dash?
BUMP
Old 07-29-2008, 10:09 AM
KustimKool's Avatar
KustimKool
Nobody knows which ignition switch I am in need of when using a tank mounted dash (ignition switch relocated on top of tank)? keeping my bike off the road right now...Any help is greatly appreciated!!
The tank is similar to this one (see the ignition switch on top) :
Thanks!
Old 07-29-2008, 11:10 AM
WVHogRider's Avatar
WVHogRider
WVHogRider is offline
No part #, but the only&nbsp\\;info I can find is that it needs to be&nbsp\\;6post&nbsp\\;Fat Bob ignition switch, and then you'll need the associated relocation bracket.&nbsp\\;&nbsp\\;Have you tried calling the dealer or an indie to see if they can help?&nbsp\\; I have the same plans for this style tank swap in the future.
Old 05-29-2012, 09:40 AM
mrdjc99's Avatar
mrdjc99
mrdjc99 is offline
Instead of making a new thread I thought id bump this one to see if in the 4 years anyone has an answer ad id like to do the same to my 05 sporty!
paulswhite
07-17-2015 10:20 PM
Brant LB Duncan
12-21-2013 09:51 AM
NE RIDER
11-10-2012 02:26 PM
BikerV
General Topics/Tech Tips
05-29-2012 10:48 AM
dwg1956
11-06-2009 08:43 AM
Quick Reply: 1993 Sportster - Which Ignition Switch For Tank Mount Dash?
