Screamin Eagle II slip ons have removable baffles?
Old 08-24-2008, 02:41 PM
chadw8434's Avatar
chadw8434
chadw8434 is offline
6th Gear
Default Screamin Eagle II slip ons have removable baffles?
do the screaming eagle II mufflers have removable baffels? i want to get a pair but dont know if the baffels remove to make it louder.
Old 08-24-2008, 03:20 PM
OldFenderGuy's Avatar
OldFenderGuy
OldFenderGuy is offline
Harley made 3 or so different generations of the Screamin' Eagle II mufflers, with each new version being slightly quieter, and offering a slightly lower performance potential.
The 'older' performance versions that have the "Not For Road Use" warning stamped on the back of each muffler (as shown below) have a removeable baffel with a single bolt holding them in place.
Not positive but I believe the "newer street legal" Screamin' Eagle II mufflers have a fixed baffel which isn't removeable.
Old 08-24-2008, 03:21 PM
plysat's Avatar
plysat
plysat is offline
AFAIK both the "old" SE II and the new street legal SE mufflers have removable baffles. I've had both types... The SE II pipes are really pretty damn loud even with the baffles in. The newer ones are quieter, but much better than stock. Baffles on the new ones are held in with 2 torx "safety" bolts, ya need a special, but easily purchased, torx bit to remove 'em.
Old 08-24-2008, 04:40 PM
chadw8434's Avatar
chadw8434
6th Gear
Where can i get a pair of those "not for road use" screaming eagle mufflers?
Old 08-24-2008, 06:43 PM
Mandog's Avatar
Mandog
Mandog is offline
The older the new ones get, the harder they are to remove. It aint easy but it can be done. The heat fuses them on. It's harder to do then to just take out those fancy tork screws. My friend made a tool consisting of a long hook attached to a slide hammer and popped them out.
Old 08-24-2008, 07:36 PM
Flatlander's Avatar
Flatlander
Flatlander is offline
Chad, I have a pair of the old SEII slip-ons. Haven't checked to see what they are going for but I am sure we could work out a deal. They have about 3500 miles on em and are setup for easy removal of the baffles.
Old 08-24-2008, 08:27 PM
chadw8434's Avatar
chadw8434
6th Gear
flat lander are those the loud ones that say not for road use?
Old 08-24-2008, 08:44 PM
schumacher's Avatar
schumacher
schumacher is offline
Here's what the older ones sound like with Big City Thunder baffles in them:
http://www.youtube.com/watch?v=_gduO0dkPlk
Old 08-24-2008, 09:07 PM
trailey97's Avatar
trailey97
trailey97 is offline
got them SEII "not for road use" on my 06 883 with the baffels removed and i love em they sound fierce pretty dang loud. been wonderin what the pythons would sound like on her. i know they are at least 135dbm on a wide glide.
Old 08-25-2008, 12:15 AM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
The ones on my 02 XL had a rivet that had to be drilled out. then I just used a bolt in the same hole.
Quick Reply: Screamin Eagle II slip ons have removable baffles?
