Odd Vibration
Odd Vibration
I've recently put new tires on the bike and ever since I've notice a vibration beginning around 50 mph. It smoothes out a little at 70 or so. I thought that maybe one of the wheels may be out of balance but if I grab the clutch within that speed range the vibration goes away leading me to think it's something else. Any help would be greatly appreciate. BTW, the bike's a 2005 1200.
I had an indy mount the tires on the rims but didn't ask if he balanced them. Most of the guys I ride with have this indy work on their bikes so I just assumed he did balance them. If it's the wheels out of balance why would the vibration go away when I grab the clutch? That's what has me puzzled.
I would be checking alignment...... and I believe I would also still be checking on wheel balance!
BTW, are your wheels spokes or mags?
Also check torque on the front motor mount. When you clutch it, the engine revs down and a loose front mount bolt vibration would settle.
Well in that case the vibrations must be coming from the engine/transmission putting some torque on the rear wheel. Pulling the clutch and free wheeling doesn't stop the drive belt from turning in the transmission but it does stop the engine from transmitting torque!
The wheels are spoke front and rear.
That was it. I compared the belt tension on my bike to a friend's 1200 (same year/model as mine) and noticed the belt tension on his bike to be higher than mine. Saturday I adjusted the belt, took her out for a ride and the problem is solved. Thanks everyone for your help.
