plug gap confusion
Old 12-27-2008, 09:10 AM
emtjayb's Avatar
emtjayb
emtjayb is offline
Default plug gap confusion
ok, the service manual for my bike says the gap on the plugs should be .038-.043, and the service manual for the S&S super b carb says it should be
.022-.025. which one do I go by?
Old 12-27-2008, 11:01 AM
GazzaTheBastard's Avatar
GazzaTheBastard
GazzaTheBastard is offline
Gap has some to do with the type of plug, but mostly it has to do with the
type of ignition.
Around 0.40 sounds about right for an electronic ignition.
Points are a little tighter but not much, maybe around 0.35 to 0.38 - I don't
have a bike with points though so don't trust my numbers!!
And a magneto has the tightest gap at approx. 0.20.
The carb type has no relevance to the plug gap... so I'd trust your service
manual, if you have a stock ignition setup, or go find the ignition manual if
you have after market. And 0.22 to 0.25 doesn't sound right for anything.
AFAIK
Gazza
Old 12-27-2008, 11:02 AM
scotty-j's Avatar
scotty-j
scotty-j is offline
go with .040 personally i'd go with the service manual
check out the ironhead section over on xlforums as well, lots of good info between these two sites http://xlforum.net/vbportal/forums/forumdisplay.php?f=7
http://www.nightrider.com/biketech/hdsparkplugs01.htm
http://www.mrgasket.com/pdf/Sparkplugs.pdf
Old 12-27-2008, 11:10 AM
emtjayb's Avatar
emtjayb
emtjayb is offline
thanks guys
hdwd2000
05-25-2017 08:37 AM
clap
10-03-2015 09:51 AM
Traxxtar
05-21-2015 09:36 AM
HogNewbie
09-18-2009 08:03 PM
csd4682
Ironhead
05-27-2008 10:59 AM
Quick Reply: plug gap confusion
