Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Sportster Models
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Sponsored by: Rush Racing Products
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 01-15-2009, 08:47 PM
magnum629c's Avatar
magnum629c magnum629c is offline
Default will a S&S Carb or c/v add power?
I have a stock 1989 1200 with a c/v carb, drag pipes and ss air cleaner. I have a few bucks to spend and would love to change over to a new s&s carb and trash my c/v. I do not want to change my pipes or anything else I like the bike the way it is but would like to upgrade the carb. Would the s&s carb alone add any power? I dont care about the money and I know the c/v carbs are very good but would love to try one. So is a carb a carb? I did hear from one guy years ago that there the best thing ever and add 4HP but not sure if the guy was right. Thanks
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
2003 softail standard
100 anniversary numberd paint set
42mm mikuni flat slide
S/E air cleaner
V&H pipes
arlen ness 3+ inch forward control kit
S/S 12 inch apes
Old 01-15-2009, 11:13 PM
stng_96's Avatar
stng_96 stng_96 is offline
It will deffinately help. It will help you take more advantage of your already free flowing exhaust and intake. Don't get one too big though, otherwise it is just a waste.
__________________
2006 XL1200C-Rich Sunglo Blue
V&H Short Shots, Screaming Eagle Heavy Breather, Mikuni HSR42, Drag Bars, Chrome
A brave man will not live forever, but a coward will never live at all
Old 01-16-2009, 12:58 AM
JosephGarcia JosephGarcia is offline
get one that is the right size bore for your engine.
think about it like this, the size of your carb is the real MAIN jet for your engine. the maximum amount of air that the engine can inhale at any given moment will pass entirely through your carbs throat. we know that smaller holes make a given amount of air travel faster, and a larger hole passes more air at any given moment, but the air travels slower.
in an engine, you want to be able to get as much air in as the valves open, there is lots of ways to do this, but a properly tuned street engine will have a somewhat smaller diameter carb bore so that the air flows faster into the combustion chamber, this increases peak torque and real world power at the cost of peak horsepower at your rev limit, but no one on the street uses that power.
i know it seems long, but if you are serious about adding noticable power than by all means get a carb with a diameter equal to your stock carb unless you have lots of headwork and cam work done, in which case it is better to have a slightly bigger carb to take advantage of that flow.
the biggest advantage to the aftermarket carbs is how they mix the fuel and air and deliver it to the engine. which is to say that most of the good ones will make more power than a stock carb.
either way, send me your old stocker carb when your done, i can put it to use!
(im serious, ill even pay for shipping)
__________________
Proud owner of a Goldwing!
Old 01-16-2009, 08:31 AM
rodhotter rodhotter is offline
Prospect
there is very little difference in carbs in a non racing application, a correctly sized + jetted carb is most important, those drag pipes are killin lo + midrange performance for sure
__________________
bernard j czech
Old 01-16-2009, 08:45 AM
sharkey's Avatar
sharkey sharkey is offline
If it was me; I'd get a pair of pipes (Khrome Werkes are my favorite; sleek one-piece stock look, deep sound and well made) and a dyno tune.....no aftermarket carb parts; just HD jets as required.
That's what I did when I had my Sporty. A good solid "baseline" for future mods and a bike that's making the HP built into it. My '01 ended up at 100hp/88tq with the help of HeadQuarters; was a real blast to ride.....
Old 01-16-2009, 08:47 AM
cHarley's Avatar
cHarley cHarley is offline
Quote:
+1 If you are looking for better street performance, get rid of the drag pipes.
__________________
IF YOU CAN'T RIDE IT OR TAKE IT TO BED, IT AIN'T WORTH HAVING
Light travels faster than sound. This is why some people appear bright until you hear them speak.
04 1200C
Old 01-16-2009, 08:50 AM
EVO80's Avatar
EVO80 EVO80 is offline
I doubt that you will see any improvement that will justify the expense of the new carb with a stock engine - if you do see a big improvement it will be because your current carb is not jetted properly. The CV carb will flow enough air to satisfy the engine and when jetted properly will give you a great bang for the buck. If it was me I'd spend the money for the new carb on a dyno tune to maximize what you currently have. BTW, I am a big fan of S&S carbs but I think on a stock engine the CV carb is fine properly set up.
And I agree with the others comments on the drag pipes. At a minimum I'd add a washer lollipop to assist with the low back pressure. This is a cheap solution to improving the dip in low/mid range performance casused by the drag pipes.
__________________
BLOODSHOT
2007 Streetbob
<a href=http://insanefrog.com/images/bike_clean_for_web_jpeg_small_size.jpg target=_blank>http://insanefrog.com/images/bike_cl...small_size.jpg</a>
Old 01-16-2009, 10:00 AM
Sick1200's Avatar
Sick1200 Sick1200 is offline
I have an S&S on my 1200 and dislike it very much. No matter what, when you gas it from the line there is a slight hesitation and then it goes. Mikuni is the way to go, and if you ever take your bike to higher altitudes the S&S doesn't compensate and your bike will run richer due to the altitude change. Get rid of them drags, or put some baffles in to increase some hp, but don't waste your money on an S&S. I like that S&S is made in America, and they do put out quality products but their carbs just don't perform like a CV.
__________________
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. - Thomas Jefferson
Old 01-16-2009, 11:36 AM
robzuc97 robzuc97 is offline
Buy a cam and heads! A properly tuned CV carb will work fine until you start adding other mods: I have an '01 XL1200c with stock CV and Drag Specialty drag pipes (that's it so far) and pulled 75 HP/68 torque when I dyno'd it at school and re-jetted (which is not too shabby with the drags although hindsight I'd have bought a "better" set of pipes). Drags pipes do have their limitations but can be "tuned out" (I actually lose more high end now) for better cruising.
__________________
"Each of us, having received several hundred dollars, passed the time gloriously, spending our money freely - never thinking that our lives were risked gaining it."--Kit Carson
Old 01-16-2009, 05:22 PM
magnum629c's Avatar
Talking
I like my bike loud and love the sound drag pipes make so ill never change pipes. I live near a biker gang and a freeway and thats all I hear is bikes run wide open all day long past my house. I ride with about 10 harleys all running wide open pipes even the bikes I see all over my area run st8 drags. Its funny to hear how much people hate drag pipes on here before this forum I never new there was other pipes on the market. I really dont care about the power loss from the pipes I just wanted to no when I change over to a s/s carb if i would pick up a few HP. The bike has great power getting a few more HP would allways be nice lol
__________________
S/E air cleaner
V&H pipes
S/S 12 inch apes
Tags
1950, 1950s, 883, air, breather, carb, cleaner, cv, drag, harley, jetting, panhead, pipes, sportster, ss
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
Advertising Information - Harley Davidson Forums - Archive - Top
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
