yea I have that, but then there is also an inline fuel filter in the fuel line a couple inches below the fuel valve. i am wondering if it is supposed to be there. because I seem to be having some problems with my fuel being restricted. so I wanted to see if it was supposed to be there ( or needs to be there) before i try taking it off.
Be sure you have good plugs too... I'll have a problem with mine ocassionally, it's cold blooded and the plugs have a tendancy to foul. I'll take them out, sand blast them, clean them up and reset them. RUNS LIKE A CHAMP!
Skulls,
what kind of trouble are you shooting?maybe I can help?I figure you may have something plugging the petcock itself.(considering you have an older bike,clean out that tank real good and buy a new petcock)what are the problems your having?
Whatever you do, don't leave the petcock open when the bike is off . If it's no good replace it. If gas leaks down the cylinder walls it will not only eliminate any oil on the rings on startup, it will contaminate the oil. #1 problem for engine rebuilds.
