new 883, 1st oil/primary fluid change question
2019 Heritage Classic 114 M8 (09-23-2021)
I dunno about VERY BAD...it's not the BEST, but it's definitely not the worst. Don't use it in your primary...I will say that. But for engine, I usually run about 2-2.5 quarts a change and I have never had a problem.
Also, every other time you change your oil, I'd recommend running some SeaFoam through the crank case before you drain it. NOT MUCH! About an 1/8th to a 1/4 of the can will do it, but it will clean a lot of the sludge out of there. Run it for about 20-30 minutes around the neighborhood or something then drain it while it's still hot.
I change my oil every month and a half (daily rider - until I tore it apart) and I usually alternate the seafoam...do the oil one change, put it in the tank/carb the next. And follow the directions.
Next time I run it through the tank/carb I'll pop the carb off and take some pics. The back of my intake valves and the inside of my carb/intake manifold have looked damn near brand new since I rebuilt the motor over a year ago. It's good ****.
Maskedman --
Don't over-think this. There is nothing wrong with the HD products; they will work just fine. The other oils recommended will also work fine. Most riders seem to have a favorite, and believe the others are crap.
Bottom line, just use the correct *type* of oil in each hole, at the recommended intervals -- the brand is mostly irrelevant.
Best advice you can receive is to get the service manual. Worth its weight in gold.
Hi Guys
I'm about to do this but cant get a lot of the oils people mention. So I went for Castrol Syntrans Multivehicle 75W-90 which isa GL4 API spec oil. Anyone else used this? I wont get clutch clip with this will I?
Thanks
Thanks
