Inspection cover leak
Changed the transmission oil on my 07. Took off the inspection cover to add a qt of mobil1 and installed new gasket and o rings on the screws. used antiseize on the screws. Took the bike out for a spin to get hot and its leakings. Not around the screws but at the bottom of the inspection cover plate. Im thinking i might have pinched the cover and thats why its leaking. The gasket is the new style thicker gasket and not the old style flimsy rubber one. Gonna try to reseat the gasket and torque screws to specs. My question is will a little pipe dope or gasket sealer around the gasket hurt or help? Thanks in advance for any experinced advice.
Harley changed the inspection cover it takes a different gasket . You still can get the old style gasket off of ebay item #: 260379771395 (34986-04).Or just change to the new style inspection cover part # 34993-04a .Do you still have your old gasket i would just put it back on.
On my wife's '09 I couldn't get that darn gasket to stay put long enough to get the derby in place. I finally resorted to vaseline in the gasket groove to hold it. I figure it's petroleum based, it's not gonna hurt anything. It was the only way I could get it to stay put so I could install the derby.
yes...I just ordered the old style off of ebay .I have also heard of people using 2 of the new style gaskets with the old inspection cover some say that it works.
tighten hex socket screws to 40-60in-lbs(4.5-6.8nm)
this will help http://xlforum.net/vbportal/forums/s...spection+cover
