Wide glide on sportster
Old 04-07-2009, 09:26 PM
PUBA ONE's Avatar
PUBA ONE
PUBA ONE is offline
Question Wide glide on sportster
Need some feedback please !! I am considering putting a wide glide front end on my '06 1200 low. Any tips, pro's cons, suggestions would be appreciated.
Old 04-07-2009, 09:32 PM
deadhead111469's Avatar
deadhead111469
deadhead111469 is offline
I discussed this with my indy this morning.....he quoted me a complete WG front with chrome lower legs for $550 plus labor
Old 04-07-2009, 09:39 PM
Lindsey141's Avatar
Lindsey141
Lindsey141 is offline
I did a mid glide to mine and I think it looks like a natural fit.
I was a little concerned about the wide lookin to big for a sportster but I have since changed my mind.
I"ve since seen some with the wide glide that looks pretty cool
Old 04-07-2009, 09:41 PM
old skool1983's Avatar
old skool1983
old skool1983 is offline
JMO but wide glide is to big for such a narrow bike. biggest i would go would be mid.
Old 04-07-2009, 09:53 PM
oinker02's Avatar
oinker02
oinker02 is offline
I did a mid glide for a friend. We elected to go with a 3 degree rake also. It turned out super sic. He loves it.
Before you go total wide glide, consider a mid glide with 41MM tubes vice the stock 39's....the fatter tubes satisfy the beefy look you want without overwhelming the rest of the bike and keep it balanced looking.
Old 04-07-2009, 10:13 PM
deadhead111469
When I do mine I plan on installing a fatbob tank as well to offset the look of a WG frontend
Old 04-07-2009, 10:25 PM
OldFenderGuy's Avatar
OldFenderGuy
OldFenderGuy is offline
I'm running a chromed upper/lower WideGlide front end, with the 41mm tubes, braided brake cable and chromed 4-piston caliper.
Just my opinion of course, but I think it looks pretty good, and the longer wheelbase and 'stiffer' 41mm tubes really help to firm up the suspension and get rid of the choppy feeling I noticed with stock 39mm setup and short wheelbase.
Old 04-07-2009, 10:33 PM
oinker02's Avatar
oinker02
oinker02 is offline
deadhead, the fatbob tank ain't necessary with the fatter custom tank you already have, but it looks good if you go that route.
oldfenderguy, you might want to consider sliding your fork tubes up an inch or two to relevel the frame with the ground.....not only will it look better, it will handle much better and also allow you better footing and not lean over so much on the jiffy stand.
Old 04-07-2009, 10:56 PM
deadhead111469
I want the speedo down on the tank, there's only a half gallon difference in fuel. but to get the look...and them ez-bob kits look like sh*t
Old 04-08-2009, 12:28 AM
Biptastic's Avatar
Biptastic
Biptastic is offline
I have a 5 degree wide glide on mine. Theres pics in my profile of the front view. Bip
Quick Reply: Wide glide on sportster
