Roland Sands vintage bar question
I'm fixing to bolt mine on this week for final install. I went with 23.5" upper brake hose, +4 on throttles, +10 on clutch(because of extreme bar angle).....All cables from Magnum shielding.
I'll warn you of something very critical........you absolutely MUST modify how they attach at the risers. The stock risers will allow the bars to spin due to shallow knurling on the bars....My simple and effective solution was to use two strips of drywall sanding cloth cut 1" wide and long enuff to circle the bars when clamps installed.
Other than that, the RSD bars look killer and are top quality. They are also easy to wire internally.
New risers won't correct the problem...The problem is the knurling on the bars. The knurling isn't done deeply and sharply enuff to allow the risers to clamp and "bite" into the bar knurling.
facing the same question with mine at the moment. i did exactly what you did, mini apes and black diamond extended cables and just purchased some 14" mini gimps. looking at my bike it looks like i should have 2 extra inches of cable but until i get them i just won't know for sure. if you're staying at the same height you should be ok. i also heard that hockey tape should hold them in place. wrap around once or twice on the clamping area and bolt them on. good luck and post pics when you get them on but i just noticed something, looks like they're already on in your sig pic.
BTW, you got one really hot scoot...I'm jealous
