top speed for 883 sportster
I'm off about 5-6% (high on the bike speedo) compared to my Garmin. My dad is off a little more on his bagger. When I indicate 100 mph my gps reads about 94.
I trust the GPS.
My busa is worse. It's off right at 10%. At an indicated 175 at Texas World Speedway's front straight my datalogger tops at 157.
I trust the GPS.
I trust the GPS.
(it's 13% low btw I got it used and the fool that ordered it new got a 4x4 with little bitty passsenger car tires on it)
You got that backwards. The data logger can't figure out what your tires are doing, so it has the same problem as your speedo. They get their speed info by counting the revolutions at the transmission. Tires get smaller with wear, but still stretch some when spinning, so you never really know precisely how far you go for each revolution of the wheel.
The GPS might be a few yards or meters off in your position, but the rate at which your position changes is going to be VERY accurate in a straight line and steady speed.
If anything, the GPS will actually read a little low. A GPS calculates speed assuming you went in a straight line since your last position fix. If you didn't go straight, you actually had to travel farther in the same amount of time.
Frankman740 (07-05-2021)
