Battery Location
05-13-2009, 02:49 PM
Battery Location
Hi all. Probably a bit of a stupid question (I am a new Harley owner) - but where is the battery located on my XL1200N and how easy is it to access?
Many thanks!
05-13-2009, 03:50 PM
left side cover
when removing cover lift up and out or you break the plastic tabs (top only)
look in owner manual
Quote:
Originally Posted by
thecommonenemy
Many thanks!
behind the panel (lhs) of seat (same looking panel/cover as your oil tank)
05-13-2009, 03:52 PM
left side, behind that plastic cover, I believe you got to remove the seat then pull the cover off. whatever you do, make sure you get the cover good and snug back on or most use zip ties to hold it on. the clips do not hold very good and you will lose it going down the orad
05-13-2009, 04:02 PM
Thanks!
Cheers guys! Appreciate the replies.
TroutBum
01-02-2018 12:42 PM
green hd
Screamin Eagle CVO Models
05-29-2016 06:55 PM
bobbbey
05-29-2009 09:42 PM
8541hog
09-03-2008 05:33 PM
freekinfreak
12-17-2006 12:09 PM
1200n ,
2008 ,
2009 ,
883l ,
battery ,
davidson ,
frame ,
harley ,
located ,
location ,
removal ,
sportster ,
where ,
xl1200n ,
xr1200
