2002 883 Backfiring, No Power
Old 07-26-2009, 01:10 PM
rider1984's Avatar
rider1984
rider1984 is offline
1st Gear
Default 2002 883 Backfiring, No Power
I didn't ride my bike for a week or more and when I went to ride it yesterday it started and idled funny. I noticed that the rear cylinder was not firing. I let the engine cool and removed the spark plug from the problem cylinder. It seemed like the plug was fouled so I cleaned it up and put it back in. Started up and ran great through my hour ride. Today I thought if one plug was fouled the other may be close so I removed both and clean them. Upon putting them back in and starting the bike I had the funny idle, backfire, and no power. Both cylinder are firing this time but still having the problems I mentioned? Any ideas? Should I try new plugs?
Old 07-26-2009, 01:56 PM
McGowan128's Avatar
McGowan128
McGowan128 is offline
Stage IV
did you check the coil wire? mine came off the other day and sounds like the problem your having, just a thought
Old 07-26-2009, 02:44 PM
Bentwrench's Avatar
Bentwrench
Bentwrench is offline
Default Misfiring/Poor Idle/Fouled Plug
With a 2002, unless they have been replaced, I'd check the resistance of the plug wires. Even if fairly new, since you're experiencing a problem, I'd check their resistance anyway. Also check that the coil terminals are clean and free of corrosion. Excessive use of the enrichener tends to foul the rear plug. Use as little enrichener as you can to avoid plug fouling. The 2002 had the vacuum petcock, and if that has a slight leak it will deliver raw gas to the intake manifold, which can also foul plugs. New plugs would be a good idea, but if they foul again, then you'll need to find the reason they're fouling. Wrong jetting, float level too high, excessive use of enrichener, leaking vacuum petcock diaphram and exhaust reversion are some of the common causes of plug fouling. Also, numerous short trips or continuous low rpm running can foul plugs. A weak ignition system can also contribute to plug fouling.
Old 07-27-2009, 08:18 AM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
Originally Posted by 4273097130
Cya.
Old 07-27-2009, 08:20 AM
xFreebirdx's Avatar
xFreebirdx
Wouldn't hurt to put some new plugs and wires on it. That should be done every so often just as a part of preventive maintenance. The frequency of when to do it has a lot to do with whether you park the bike outside or inside, etc..
Old 07-27-2009, 08:33 AM
cHarley's Avatar
cHarley
cHarley is offline
+1 for as little as $1.50 ea at your local auto parts store for Champion RA8HC's why even bother cleaning your plugs.
If in doubt, throw them out.
laserman2431
09-25-2012 04:55 PM
Razorback Rob
12-31-2008 09:19 AM
bob53
08-18-2008 08:16 PM
PMZ XL 1200
04-19-2007 08:58 AM
KenM
Exhaust System Topics
06-03-2006 10:16 PM
Quick Reply: 2002 883 Backfiring, No Power
