fuelpak help: will stage 1 dealer download work with fuelpak?
I have the Fuelpack on mine and from what I hear you should not run the stage 1 download and fuelpack together? Is this the case? I was thinking about getting the stage 1 download myself and nixing the fuelpack because I was getting a lot of decel popping, but that seems to have settled down a bit now.
Decel popping
Cat, hopefully no offense calling you that. I am in no way an expert on Harley because I have only had my bike a month, however, it appears that you do not have factory pipes and if they didn't replace the exhaust gasket, that could be causing your decel popping. Only a suggestion.
If you haven't been to the V&H website, check it out, I think there may be some info regarding this configuration. Or just call V&H.
hey all thanks, i just got my map.
but I'm still a bit unsure that what if I mess it up and couldn't get the fuelpak install, then I went back to my original setting(which was the stage1 dealer download, will the download still be there?or they are gone forever??)
*one of you guys told me that the fuelpak will overwrites and reflesh it???!!
