Horn???? What a joke
RE: Horn???? What a joke
I ripped out the stock XL883 horn
and installed a
(Low Note)
FIAMM
Freeway Blaster
$15.00 @ Advanced Auto Parts
Extra Loud for Passing Safety Approved to EEC Regulation 28
The Freeway Blaster Horn is designed for addition to, or replacing, the original equipment horn(s) to alert drivers in noisy and high speed traffic. Versatility and rugged construction are major selling points of this horn. Features steel housing and plastic projector. Copper wire coil motor. Available with universal mounting bracket or right angle bracket. Corrosion resistant finish. Each horn is tested to assure maximum performance. High or low note (one or two terminals). Can be mounted singly or as duals. Made in the U.S.A
Terminals: two
Dimensions (L X W X D) 9 1/4 X 6 5/8 X 3 1/2
Frequency (Hz) 405
Min dB. Rating @ 4" 130
Current Draw (AMPS) 5
Bracket Universal
Power Source 12V
and installed a
(Low Note)
FIAMM
Freeway Blaster
Terminals: two
Frequency (Hz) 405
Bracket Universal
Power Source 12V
The stock horn on the 1200L is louder than the stocks on the two Triumphs that I owned. I've used the dual Fiamms on one bike, but not the H-D. They came in a kit with a relay and all of the wiring and terminals that you need. An easy electrical install, but difficult to get both of them mounted on the bike. They are louder individually than that on theSportsterbut working together they seem louder than they should because the tones selected create a discord. Another option is the Stebel Nautilus, I heard one of those demoed at a bike show, very impressive but its difficult to find a place to put ir without it looking really ugly.
