Broken Odometer, common?
Hi, I'm looking at buying a 1998 Sporster 1200. The price is good but I notice that the LCD odometer is damaged and only the last two digits can be read. There doesn't seem to be evidence of tampering but the molecules have just gone nuts. Is this a common problem?
There is no record of mileage but the owner assures me that the bike has done around 16,000 miles. It is very clean, seems to have been looked after, and runs and sounds great. Should I buy or leave alone?
Isn't the 1200 bulletproof? What's the worst that can happen?
I've never heard of that as being a known/common problem. You can always order a new odometer through the dealer, and tell them a mileage that is close to your buddies estimate to have programmed into it. I wonder if the dealer/MOCO has an attachment that they could read the speedo readings/codes like through a laptop or something.
Even if the odometer worked that dosen't mean the reading is accurate. It could have been disconnected for a while or even replaced with one with lower mileage. Look at the overall condition of the bike if it was well cared for it will show. There is one trick I use that works sometimes to tell if milage is accurate. If the tires were not recently replaced, look at the date code on the tires and how much tread is left on the tires. If the tire is 4 or 5 years old and there is not a lot of wear on the tire then the is most likely correct. Whereas if the tire is only a year old and has a lot of wear then it most likely has more miles then they are saying it has.
