2006 XL1200C bars & risers
I'm currently running the stock pull-back riser with a drag bar on my 2006 1200 Custom. Anyone familiar with the 2004-up Sportster Customs should know that the speedo housing is built into the riser clamp. Now, I want to replace this set-up with a set of 6" straight risers with flat-track style bars, however, the riser clamp with built-in speedo doesn't seem like it will fit any other riser combination besides what comes stock on my bike. So, my question to the masses is how do I pull off this mod without ditching my stock speedo...?? The only way I figure I can get around this if I find a pre-2004 1200 Custom speedo housing and riser set-up because these had the 6" straight risers instead of the pull-back style.
Any help would be greatly appreciated.
Thanks!
Thanks!
This tread topic has popped up quite a bit recently and your response is all the same. "Do a serch for the thread "Apes or Drag bars" haha.
wes mullen - its just the stock 2005 1200C riser with speedometer made into rear part of top clamp and idiot lights in the forward part of the top clamp.
JustinDap - I don't mean to sound like a broken record but that thread contains a lot of information about alternative methods for mounting the speedometer. Just thought it would be easier to refer questions to that thread instead of going through it all again. I'll give it a rest.
That sure is a nice paint job you got there.
