Lower Engine Mount Bolt Loose
For those of you that have the rubber mounted engines (2004-2006 Sportster) you may want to keep an eye on the lower engine mount bolt located up front below the voltage regulator (X). I've read on other forums that this bolt tends to work loose. I would also keep an eye on the two bolts that mount the stabilizer link to the upper front cylinder head. My bolts worked loose in less than 1,200 miles!
