Dyna front end and 16" wheel on a sportster???
Old 11-16-2009, 12:24 PM
rcsoftail's Avatar
rcsoftail
rcsoftail is offline
Default Dyna front end and 16" wheel on a sportster???
Have an 08 sportster low and a set of triple trees and 49mm forks from a dyna. Will they fit? Will a 16" front wheel from a softail fit in a sportster with a mid-glide conversion or is the hub too wide? Ultimate goal is to get a sportster with a wider front end and a 16" wheel. Any issues with factory rake? thanks
Old 03-20-2011, 02:48 AM
prattbratt's Avatar
prattbratt
prattbratt is offline
I'd like to bump this post since I have the same question. I'm looking to maybe just replace the triple trees on my 08 sportster ees to make the forks a little wider.
Old 06-13-2012, 03:12 PM
mumeral's Avatar
mumeral
mumeral is offline
I just wanted to bump this thread, and ask if there's a specific donor to look for a mid or wide conversion on an 09 nightster.
Old 06-13-2012, 04:22 PM
mreed's Avatar
mreed
mreed is offline
Factory HD 16" wheels will not fit in a MID glide. The hubs are just too wide.
Factory HD trees that run a 16" wheel have less neck stem to fork tube offset. This will not affect your rake unless the length differs from your stock front end. However, it WILL increase your trail. Do the calculations before you purchase.
www.vulcanworks.net sells everything you need to run a 16 with your stock fork legs. Give them a call because not all of their info is on their site.
The bike in my sig pic has a 16 in the stock narrow glide front end. Since you guys haven't found info here regarding a 16" front wheel I thought I'd throw that in there to make you wonder.
Old 06-13-2012, 06:14 PM
mumeral's Avatar
mumeral
mumeral is offline
I brought this from the grave because it's similar. I really don't have a preference, I would like to use my stock rim just relace a donor front end from a dyna. I was just wondering which front end I should be on the look out for. Ergo 2010 FLXP or whatever.
rdrnr03
04-07-2020 04:00 PM
zigzagman
10-31-2018 07:42 PM
jrpitty
03-23-2013 11:46 PM
20Sporty06
06-10-2010 09:22 PM
harley9701
05-24-2007 06:18 PM
Quick Reply: Dyna front end and 16" wheel on a sportster???
