sportster shut off going 50
Old 11-18-2009, 01:14 PM
3rdgear's Avatar
3rdgear
3rdgear is offline
I had the same issue.. ended up being the battery.. the thing was going bad and I didn't know it.. until it started leaking battery acid.. got a new gel cell.. I've only had it in about a week and seems to be running a hell of a lot better.. and haven't had the issue yet so hopefully its the end of it.
Old 11-18-2009, 04:49 PM
JW1200's Avatar
JW1200
JW1200 is online now
Received 20,866 Likes on 8,236 Posts
Originally Posted by Nonstop
Loose negative battery connection.
+1........
Old 11-21-2009, 10:57 AM
WRAITH's Avatar
WRAITH
WRAITH is offline
I've had the same thing happen 4 times. Everything goes completely dead for a split second. The engine re-fires on its own. I've checked for codes but found none. I checked all of the electrical system. It hasn't occurred in the last 40,000kms but that doesn't mean it's fixed.
Old 11-21-2009, 05:51 PM
Badass67stang's Avatar
Badass67stang
Badass67stang is offline
I put a new battery in the bike and rode it today for about 20 miles and it didnt do it.
Old 11-22-2009, 09:33 AM
DENGUY's Avatar
DENGUY
DENGUY is offline
Just had to change the ignition switch in my 95. Wasn't making consistant contact inside.
Old 11-23-2009, 12:20 PM
Badass67stang
went another 75 miles on sunday again with no problem hope the battery was it
Old 11-23-2009, 07:44 PM
NI-STER's Avatar
NI-STER
NI-STER is offline
This is what happened to me (3 times). The 4th time it actually shut down completely. I had nothing,(lights,starter etc)Then it decided to start. Went straight to the dealer and said WTF! They were too busy to look at it but said a loose Neg. connection is a common issue. Checked, and sure enough it was loose.
Old 11-24-2009, 06:39 PM
ronn39's Avatar
ronn39
ronn39 is offline
50 mph in 5th gear and you "gunned it?" Might get away with the lower gearing of an 883, but my 1200 would strongly object to doing that.
Old 11-24-2009, 07:04 PM
Badass67stang
wow luckly i was on my lil 883
Old 11-25-2009, 10:05 AM
3rdgear's Avatar
3rdgear
3rdgear is offline
If I tried that my bike wouldn't like it very much.. I would say 4th would be safe.. maybe even 3rd.. but I wouldn't do it in 5th.. cant be too good on the engine..
gNut
Electrical/Lighting/Alarm
08-27-2016 05:03 PM
mthew96
04-15-2015 11:35 AM
joebotics
08-01-2011 08:02 AM
axle357
05-07-2011 08:16 PM
tackleberry
03-11-2009 01:01 PM
Quick Reply: sportster shut off going 50
