wheres my factory alarm module ???
Old 11-21-2009, 10:21 AM
jerryw618's Avatar
jerryw618
jerryw618 is offline
Question wheres my factory alarm module ???
hi there i have a 2007 xl883l , i think it has a factory alarm i have a key fob i need to run the bike , but i recently installed a scorpio alarm , and now sometimes i cant start the bike , the lights all flash the red key light is on on the speedo and it just wont turn over . if i turn the key on/off a few times and/or push the scorpio alarm button i eventually get it too start and run , but i think i want too pull the factory alarm and use the scorpio , i cant seem to find the factory alarm module ? its not under the seat , thats where i put the scorpio alarm .?? any ideas ?????
Old 11-21-2009, 10:29 AM
Sporster2009UK's Avatar
Sporster2009UK
Sporster2009UK is offline
not a 100% sure, but can you not just pull the fuse to the alarm?
Old 11-21-2009, 03:50 PM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
If I am not mistaken, I think it is between the battery and the fuse box or just behind the fuse box in that area. Not sure if you can just eliminate it or not, but you should be able to disable it by putting it in the service mode.
Old 11-21-2009, 04:38 PM
HarleyScuba's Avatar
HarleyScuba
HarleyScuba is offline
The alarm is tied into our turn signal cancelling unit. To get rid of the alarm and keep your turn signals, you'll need the "stock" turn signal module from Harley (no alarm). The dealer I worked at used to put the factory module into inventory when an alarm module was installed. There were a ****-ton of 'em. The part # is in the Parts Manual for your bike. It shouldn't cost too much. Service mode sounds like a potential option, too.
Leroy54
03-10-2021 08:47 AM
Mr Bentwrench
02-03-2014 11:26 PM
GeorgiaGlide
06-22-2013 10:15 AM
mccstevie
01-13-2013 03:14 PM
dbalogh
03-27-2008 10:13 AM
Quick Reply: wheres my factory alarm module ???
