Heated Gloves vs Heated Grips
You live in Iowa. I've got the grips and they work just fine...but I live in Cali. If you ride in inclement weather, I would recommend you get the gloves as they'll work better for the back of the hands. Also- yes, you can get inserts for most grips that makes them heated.
I've got a '97 883 on which I just installed Heat Demons grip heaters while I was swapping to mini apes. The were easy to install, probably 2-3 hrs start to finish if that's all you're doing and taking your time, and you can use any grips you want. The switch replaces half of the clutch perch and looks like a factory option. I've ridden a couple times in temps right around 40° and had to turn them down because my hands were starting to sweat inside my gloves. The only negatives I can see so far are that in colder weather the backs of your hands and fingers will probably still get cold, and they aren't portable from bike to bike so now I have to buy another set for my Streetbob. Another interesting heated option I've been eyeing is a seat heater. http://cozywinters.com/shop/heated-motorcycle-seat.html
http://www.dual-star.com/index2/Ride...d_grip_kit.htm
and will be installing these with them.....
http://www.dollarrider.com/detail.cf...33&sblid_name=
A guy on this forum gave me the info and he has done it as well.
I am looking at these- http://www.phatperformanceparts.com/...ductCode=15855
Does anybody have any experience with them? I have heard good things about them from a few people, and they will allow me to keep my ISO grips.
