coil/ignition relocation question
I've seen a lot of people relocate there coil and ignition to the engine area. I mentioned that to the guy at the dealer and he brought up that its not good because of the heat and the vibration. It makes sense but then again he works at a HD dealership so I dont trust them. Have you guys that have relocated had any trouble and also how long have you had your relocation?
Hi there
I had the same thoughts you have and although many have done the relocation i still felt it's a little close,I moved my ignition up and just below the stearing lock.And once i get a longer plug lead i'm moving the coil to the position the horn sits at present.Ive lifted the headlight and put a new hooter in the space below it.H.
hey.. I relocated the ignition coil in the same area, although in order to avoid a possible vibration issue I relocated it by attaching the coil to the chassis instead of the top of the cylinders... about 4k miles with this mod with no issues and no need to readjust... here is the link:
https://www.hdforums.com/forum/sport...n-my-take.html
Sorry to dig up and old thread, but..
I recently relocated my key cylinder to the engine area towards the bottom. I used a kit that mounts it to the grounding bolt. I had problems almost immediately. The key seems to get stuck every time i run the bike. One of my theories is that the Key cylinder gets too hot and the metal expands, causing the key to get stuck. I have to wiggle the key back and forth and up and down until it hesitantly comes out.
Has anybody else had this problem. I'm thinking about wrapping it with some sort of thermal insulation to possibly help with this problem.
Heres why its bs.
its the same ammount of heat if you look at the position.
Vibration yeah, theres quite abit more. The guys over at DK customs include two rubber mounts that you place one the relocation bracket, one for the coil one for the key.
Gives the bike a nice clean look.
One thing though. When you do the relo, take the master fuse out first. I didnt and i zapped the vss sensor out of wack haha.
BTW..where is everyone relocating the cow bell horn when moving the coils?
Heres why its bs.
On some 48's & 72's will touch the plastic housing of the relocated key switch. This can be alleviated by choosing the Flex-Six option, or by cutting a small portion of the plastic housing.
You can look at the many options we have at the link below.
http://www.dkcustomproducts.com/Coil...ocation_c8.htm
Here is one way you can Relocate the Horn
If you have a Sportster Custom or Roadster you will need the Horn Relocation Bracket. This bracket Bolts right between the down tubes in front of the front cylinder using the top motor mount bolts.
Kelsey
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
Cristy
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
