For people that complain about a sporties power
man i get a kick otu of people that make fun of sporty's. i got a 69 xlch 900cc as my only and DD when there aint snow down. but i regularly smoke the Big twins and even some of the rice rockets off the line some people just stuck on the "its a girls bike" mentality i guess
The Ironheads came in two flavors.
The 'original' was actual 55 CI (901.3 cc's) but it was called and better known as 900 cc.
In 1972 the 55 CI Ironhead was increased in displacement to 61 cc (999.6 cc's) and was called the 1000 cc Ironhead.
In 1986 the EVO based engines replaced the old 1000 cc Ironhead engine in the Sportster lineup and it was available in two flavors, the 883 and the 1100. The 1100 cc EVO was increase in displacement to 1200 cc's in 1988.
Maybe because the old Ironheads were not 883 cc's..
See if this convinces you!!
If you insist, but I suggest you read this.
Model ID
Manufacturer (Make) Harley-Davidson
Model Name XLCH 900 Sportster
Year 1970
Category(class) Classic
Engine
Engine Capacity (Displacement) 882 ccm (53.82 cubic inches)
Engine Type V-type, 2 cylinders
Bore x Stroke Ø76.2 mm x 96.8 mm (Ø3 inches x 3.81 inches)
Bore/Stroke Ratio 0.79
Stroke 4
Valves per Cylinder 2
Timing System OHV
Cooling System Air
Powertrain
Gearbox 4 speed
Chassis/Suspension/Brakes
Front Brakes Drum
Rear Brakes Drum
Front Tire 3.75-19
Rear Tire 4.25-18
Dimensions
Curb Weight 214 kg (472 lb)
Fuel Capacity 8.5 litres (2.25 gallons)
Performance
Max Power 65.00 HP (47.4 kW) at 6300 RPM
Power/Weight Ratio 0.3 Hp/Kg
Top Speed 180 km/h (112mph)
Acceleration (dart, speedup) time
0-100 km/h 5.2 seconds
0-60 mph 4.9 seconds
1/4 mile
60 to 140 km/h, highest gear
Moto profi >> Manufacturers list >> Harley-Davidson >> XLCH900 Sportster 1970
Bike Information, Photos, Features and Reviews
Model ID
Year 1970
Engine
Stroke 4
Timing System OHV
Cooling System Air
Powertrain
Gearbox 4 speed
Front Brakes Drum
Rear Brakes Drum
Front Tire 3.75-19
Rear Tire 4.25-18
Dimensions
Performance
1/4 mile
