crankcase breather ?
RE: crankcase breather ?
I installed one about a month ago and love it. It has redirected all of the oil from being splattered on the oil tank to the ground. The only problem I ran into was taking the torx screws off to take the backplate off of the carb. I stripped two of them and had to extract them with screw extracters (pain in the azz). Just be sure you use a quality torx bit and use steady pressure. You will also need to drill two holes in the backplate, which is metal, so be sure to have good drill bits for that.
Here is the link I used as reference to install mine.
http://www.mklsportster.com/xloilblowbyarticle.htm
Let me know if you have any questions, you're gonna love it!!
AZRenegade
08-30-2019 11:32 AM
