Joker LED's
Joker LED's
I'm installing the Astro Joker tailights on my Nightster but can't seem to get the wiring down quite right. I can either have just signal and brake lights or just running lights. I didn't think I needed a load equalizer for them because it's a nightster and figured it was already setup for this. Anybody have any ideas?
Ok, so I just hooked up my Biketronics load equalizer but I still just have blinkers and brake lights. Should I have gotten the Tailbones kit instead. Is this the one that you picked up JAREL? My local bike shop had called biketronics and they said all i needed was the equalizer for my nightster.
I changed my t/s bulbs on my 08 nightster to LED and didn't need load equalizers. I just looked at their website and it looks like those are set up a a single-element bulb. All you would need is a resistor and 2 diodes (for each side) you shouldn't need a whole module for it. I did that for the LED lights for my 02 to make them Run/Turn lights. I will even make some up for you and send them to you for $10. PM me if you are interested.
