1999 1200S; Dry Oil Tank / Oil in the crankcase
Old 02-22-2010, 10:25 AM
GB_FXST's Avatar
GB_FXST
GB_FXST is offline
Default 1999 1200S; Dry Oil Tank / Oil in the crankcase
After committing the sin of allowing the bike to sit too long, I noticed that the oil tank is completely dry. I am pretty confident that the oil has drained down into the crankcase, as it did not simply disappear.
Can anyone please share some insight as to what failed to allow the oil to drain to the crankcase? I do have a service manual, and the oil flow diagram notes an oil flow “check-ball” in the filter mount. Is this offending part, or is there another check-ball or valve?
Lastly, I intend to fix the problem (either myself (if any easy fix), or at the dealership), but is there any risk or harm in running it as is?
Thanks!
Old 02-22-2010, 10:32 AM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
I can't tell you for certain if its the check ball or not....But I can tell you for certain not to run it that condition.
Old 02-22-2010, 02:57 PM
cHarley's Avatar
cHarley
cHarley is offline
Yes, it's the "check-ball" that's letting the oil leak down. The check valve may be bad or just hung open from a bit of debris.
I would add 1 quart of oil to the tank and fire it up. Leave the cap off the oil tank and let the bike run at a fast idle for a few (5-10?) minutes keeping an eye on the oil level in the tank. YES, this may cause there to be too much oil in the system once the oil is pumped back up from the sump but you can suck the excess out with a turkey baster.
Once you have the oil level stabilized in the tank, I recommend 1/2 way between the ADD & FULL marks, take the bike out for a nice long ride. After you get back, monitor the oil level for several days and see if it's still leaking down. If so, replace the check valve.
Also, if you haven't changed your oil lately, you might want to do so, AFTER you have the oil back in the tank.
Old 02-22-2010, 05:00 PM
bwana1's Avatar
bwana1
bwana1 is offline
What he said. Excellent post. Softails and sportsters have had this leak down problem forever. Sometimes it will only take a few weeks and you can tell that the oil is lower in the tank. I wouldn't even add oil, just leave the oil fill cap off and watch the level come up after you start the engine.
Bwana
Old 02-22-2010, 05:10 PM
cHarley's Avatar
cHarley
cHarley is offline
Bwana
The problem with that, is that he said the oil tank was dry and that means he will have no oil supply to the motor when he starts it. It takes a while to get enough oil back into the tank so that it is available to flow back down and lube the motor. If it was just a case of the oil level being low in the tank, that would be different.
I say better safe than sorry, even if you have to remove the excess later.
Old 02-22-2010, 08:03 PM
GB_FXST's Avatar
GB_FXST
GB_FXST is offline
Thank you all very much for your replies.
I added a quart of oil, let the bike idle for a bit, and oil has now returned to the tank. I wll change the oil.
I assume that the next step is to monitor the oil level, and fix the check-ball if the problem persists, correct?
Thanks again!
Old 02-22-2010, 08:52 PM
xFreebirdx's Avatar
xFreebirdx
Thanks for the info.
Old 02-23-2010, 05:20 PM
jag1886's Avatar
jag1886
jag1886 is offline
Nothing has failed that is normal, the check ***** leak on all the old bikes, that's why they tell you to start and run the bike before changing oil or you will over fill the oil bag and it will blow oil all over the place on startup.
You guys got to stop giving advice when you don't know what you're talking about on the older bikes.
Sure hope this guy doesn't go out and waste a bunch of money now trying to fix something that's not broken.
Old 02-23-2010, 05:43 PM
cHarley's Avatar
cHarley
cHarley is offline
Well to an extent your right, as long as the oil bag (tank) isn't empty. But only an a$$hat would recommend cranking a bike with an empty oil bag.
8541hog
06-28-2022 04:42 PM
808Brew
Oil Archive (no new posts)
09-13-2020 11:56 AM
As-21
EVO
15
04-03-2019 05:58 PM
milkman
08-12-2011 02:33 PM
dcdr
03-12-2010 03:58 PM
Quick Reply: 1999 1200S; Dry Oil Tank / Oil in the crankcase
