Electrical question 1975 XL Sportster
Old 03-25-2010, 02:23 PM
lovesindeath's Avatar
lovesindeath
lovesindeath is offline
5th Gear
Default Electrical question 1975 XL Sportster
I am re-wireing a 75 Iron and It originally had a Bosch style regulator. A solid state regulator has taken place and I am re wiring the bike. This is what I have going..
battery positive to starter solenoid terminal 3 another wire off same
terminal is going to small terminal on the starter relay. From the big
terminal on the starter relay it goes back to terminal 2 on the starter
relay. the other big terminal on the starter relay is going to the batt
positive on the solid state regulator. The A and F on the regulator are
going to my A and F terminals on my gernerator. Ignition B terminal is
going to the small terminal on the starter relay. the st and G have a jump
wire and the coil and head lights are wired off the G terminal ..
Thank you i appreciate the help
Old 03-25-2010, 02:38 PM
cHarley's Avatar
cHarley
cHarley is offline
So,,,,,, your question/problem is???????????
Old 03-25-2010, 02:50 PM
lovesindeath
5th Gear
I am just wondering if that is right? and if not what should i change I just have a headlight,generator,coil,ignition,starter button/key,starter,starter solenoid,starter relay,regulator,battery..and I was wondering where the circuit breaker should go..Thank you..I have read the schematics for hours and now I turned to the few people on the interent for help to make sure. thank you
Old 03-25-2010, 03:44 PM
cHarley's Avatar
cHarley
cHarley is offline
Sorry, but I can't really picture the entire schematic in my head and tell you it's completely correct or not. It sounds OK, but I wouldn't guarantee it without seeing the wiring and relay contacts.
As for the circuit breaker/master fuse, everything from the Positive battery terminal should pass through the fuse/breaker (probably 30 amp) EXCEPT the large positive cable that runs from the positive battery terminal to the large "Input" lug on the starter relay/solenoid.
Once you get the fuse/breaker installed, the first test step would be to turn on the ignition switch and check to see if the lights work.
Hope that helps.
jaigilbertson
05-21-2017 07:01 AM
1unclejojo
Shovelhead
09-06-2012 07:52 PM
jsa750k
EVO
10-08-2011 06:02 PM
sutphen30
Ironhead
06-10-2008 08:15 PM
saweet96
07-15-2006 03:20 PM
Quick Reply: Electrical question 1975 XL Sportster
