89 sporster-backfire
i have an 89 sportster 1200 when idle/rev breaks up backfires. If the choke is out and idling it dont do it much.
-rebuilt carb,changed plugs,plug wires,choke-check petcok
seems like gas flows little fast when i drained tank/and the overflow line is dripping gas
-before carb rebuild there was extra gas in carb and airfilter
- i am at a loss as to what could be the problem please help !
ps. ran great 3 days before then all the sudden started???
When you put the carb back on make sure you use some dish soap and water on the gasket. I did on the manifold and on the inside to the carb. just rub it on with your finger... less is more. Once it heats up makes for a nice seal.
I had a backfire problem on my 02 1200 I got last year, and I called my buddy and thats what he told me to do... worked. Runs like a clock
