Ordered wrong Revtech DFO- will it still work?
I recently added a Screamin Eagle Heavy Breather AC and Samson Street Sweeper pipes.
I ordered a Revtech DFO EFI tuner but I accidentally ordered the wrong one- I ordered the HP kit which is "high horse power, high compression" engines. The instructions says it has double the fuel range of the standard version to give the tuner the ability to add far more fuel than usual.
I compared the instructions on the Revtech website for both kits - FI-1251ST (standard kit) and FI-125HPST (high horsepower kit) and the instructions and pot settings are exactly the same.
So can I use the HP kit or do I need to re-order the standard kit.
thanks for the help
thanks for the help
Here is an email I got from Revtech/Dobeck:
"It may still work you will just have to cut your settings in half on the yellow and red. Here are some settings to try:
Green: 2:30
Yellow: 2:15
Red: 2:00
RPM: 4:30
Let me know if these settings work.
Thanks,
Chris Shover
Dobeck Performance"
Green: 2:30
Yellow: 2:15
Red: 2:00
RPM: 4:30
Thanks,
Chris Shover
Dobeck Performance"
Green: 2:30
Yellow: 2:15
Red: 2:00
RPM: 4:30
Thanks,
Chris Shover
Dobeck Performance"
Green: 2:30
Yellow: 2:15
Red: 2:00
RPM: 4:30
Thanks,
Chris Shover
Dobeck Performance"
Did they work for you? If not, what did you end up with?
thx in advance,
alx
2008crossbones
Fuel Moto / Jackpot Mufflers
08-20-2011 11:15 PM
