good place to tap into the acc circuit?
Hey everyone,
Currently I am running 2 cigarette lighter style plugs hooked to the battery via battery tender plugs. I run a gps circuit on one and my MP3 player booster on the other.
I'm wanting to get these switched over to the ACC circuit and I am trying to find a good place to do so. I'm really trying to avoid dropping the oil tank to get into the backside of the acc fuse in the fusebox. Or to lift the tank to get to the ignition switch. (at least according to what the service manual says)
The reason I want to do this and not leave them hardwired to the battery is that I unexpectedly didn't ride the bike for a couple weeks and had forgotten to unplug one of the adapters. The red light on the adapter drained my battery in that time. I'm wanting to avoid this happening again.
I'm thinking that the red/grey wire would be best so that if I did have a problem with a short, it wouldn't affect rest of the components on the acc circuit since it would be before the fuse for it.
Any tips or advice would be greatly appreciated.
MH
MH
It's real easy, you can tap in under the seat... having said that, I figured it out using the wiring diagram in my service manual, which I don't have with me so... I'll check back tonite and post if you need it...
Hey everyone,
MH
MH
I just figured I'd do some asking from others experience before I go digging in too deep, since the wiring harness is sleeved.
MH
I've got the service manual and the wiring diagram in it. Thats how I knew the color wire, and what it entails to remove the fuse block etc. On my 06 (pre efi model naturally) the fuse block is above the aoil tank, not along side it like it is on my wifes 09.
MH
MH
Were are you running the wires to ? I needed power up front by my bars .And I just drilled a hole in the rear bottom of my headlight and put a rubber gromet in the hole and tap the wire inside the headlight. You can also put a small female plug into the light instead of the rubber gromet.
Keep us posted on your results...I just ordered a Battery Tender style pigtail for the same thing (GPS power). Planned to just unplug it when I am parked...if I go more than a few days without riding I usually plug in the battery tender anyway.
Tapping into the acc circuit would be a lot more permanent and cleaner mod.
I then have a second tender plug that sticks up near the seat. I plug the opposite side into that. The power outlet and my booster goes into my jacket pocket along with my mp3 player. It works but it is bulky.
This is why I want to tap into the ACC circuit so it cleans it up and I can ride with a vest or shirt and still have music since all I would need to place in a pocket is the mp3 player. I would have 2 power outlets tied to the tap and then have a tender plug that is used for only that. This also keeps me from cutting up the power cords for my devices and gives me a little more flexibility later on if I change devices. The only thing visible would be 2 1/8" stereo jacks.
I'm hoping to get it all fitted behind the battery cover. I may have to put the booster under the seat next to the ICM depending on space but I wont know until my mustang regal duke gets here.
I had thought of the headlight, but would have trouble hiding the power junction like I currently have or will have.
Thanks for the feedbacks so far I do appreciate it.
MH
Just recently did the battery tender mod to use for my gps.
The battery tender pigtail can be bought at the local auto parts store in the trailer section for under $3.
Didnt feel like looking for the right wire to tap in for the acc. Plus its easy to unplug the whole setup after the day's ride.
