Rear brake pedal
Rear brake pedal
I did a ride this past weekend with a bunch of crazed metric riders (never again). Trying to keep up with my '08 Nightster was interesting. I had to use the brakes fairly hard to slow for the turns. In my "panic", I realized that my right foot was slipping off the brake pedal at times. I'm now watching more closely and I see that my right foot, in normal riding position, only covers 1/2 of he brake pedal. My foot is slipping off the right side of the pedal. I would like to install a larger pedal. HD doesn't really have anything. Does anyone know of an aftermarket larger brake pedal that fits the Nightster? Or perhaps I can replace it with a pedal from another model bike.
I know I may be a little paranoid, but I would feel more comfortable knowing that the full pedal is directly under my foot at all times. I know forward controls may help, but I do like the mids. Thanks, Ron.
I recall seeing (maybe on this forum) a modified brake pedal where the pad was cut off and a shifter stud and rubber were installed. In other word the bike had a matching shifter pad and brake pedal pad.
Seems to me what you are seeking is a larger pedal pad onto which your boot applies
pressure.
I think fabrication is your option.
So maybe cut the pad in half, weld in a 1/2 extension and reassemble.
Or find a different pad and attached with bolts though the current one.
You may be able to heat and bend the current pedal assembly to a shape you like or cut the pedal and weld in a extension with a bend to your liking. I do like like the safety aspect of this option though.
pressure.
Can't recall, but it was a large pedal. I'd say 2x3.5" It was similar to this one but this one looks smaller
http://www.jpcycles.com/product/243-...0pedal&Ntk=All
There's a link to the instructions (a pdf file) you'll get the jist from that. I'll ahve to wait til I ge home for a pic of mine. Or I can go out to the parking lot and take a pciture of the hole in my stock pedal HA HA
