Deuce wheel 04 on my 06 custom
And could you tell me what was the length of the bearing spacer tube that came out of the deuece wheel as i just done this and just took out the tube and ran my one inch bearings and axlew n destroyed the 1 inch bearings due to not having the bearing spacer tube now im going to just put the duece wheel on my 02 wideglide but now i need the tube for the duece wheel as i lost it after i took it out please help
update
I used an axle from 04 sporter with the homemade spacers until a year ago. I then found a later model wheel. After 07 or 08 they all went 25mm so i was able to put 1inch bearing in that wheel and go back to my 1inch axle. Hd has kits of a new spacer and bearings. The spacer for the 3/4 and 1 1inch are the same length but the 25mm are longer due to the bearing being narrower.
I used 1" bearings by buying an H-D bearing kit. They are sold to fit custom wheels and come complete with the spacer that fits between the bearings. That provides the dimension, allowing for suitable running clearance, for boring the hub. My local Yamaha dealer race prepares bikes and did that for me.
That way you can use your 1" axle and spacers etc. Someone with a later Sporty that has 25mm bearings can do much the same. Hope that helps!
