Screamin' Eagle Heavy Breather?
I'm going to pull the trigger on a new air cleaner sometime this week, and so far I've come along the Screamin' Eagle Heavy Breather.
This will allow me to use the FuelPak I have. What kind of performance gains will I be looking at? Is there another one that I should consider? Looks aren't the deciding factor here.
And DIY is not an option either. :P
The heavy breather is a good choice, will actually give you more leg room than the old ham can did, and breathes way better. I ran a Forcewinder on my Sportster and the heavy breather is basically the same thing. You'll need to keep the "sock" with you for those times you get caught in the rain, or like me, just keep it on all the time.
The Heavy Breather is a good option, and in my opinion one of Harley's options that aren't hugely overpriced. And you can use whatever fuel management system you want, it doesn't have to be the Harley one if you don't want to. You can use any fuel management system with any air cleaner (technically), the only difference may be a little performance depending on which you pick.
