Bike shuts off while riding!!!! WTF?
Old 09-06-2010, 09:54 AM
HD Buyer's Avatar
HD Buyer
HD Buyer is offline
I have seen the TSM (TSSM) cause this problem. The sensor that measures lean angle and will shut off the motorcycle if it tips over is in this module.
Old 09-06-2010, 10:10 AM
sooie's Avatar
sooie
sooie is offline
ground to battery good (could not move it with a wrench)
cleaned both battery term. with a SS brush,unplugged the the gray box on the fender,the small one right at the top of the ground (battery) and the plug at the bottom of the frame. what relay are you talking about ? is it the small on next to the breaker ? plugged every thing back together and it stared right up now what ?
Old 09-06-2010, 01:13 PM
WRAITH's Avatar
WRAITH
WRAITH is offline
There is a ground connection next to the starter. Make sure it's clean and tight. My 06 has done this 4 times in 82,000 miles. The problem is so intermittent, I haven't been able to find the cause. I know of 2 bikes that had problems with this ground wire going to the starter. The wire had internal breaks and had to be replaced.
Old 09-06-2010, 03:23 PM
Hitechluddite's Avatar
Hitechluddite
Hitechluddite is offline
Next time it happens look at your speedo and see if it drops to 0 while your still moving. If so you've got a power problem if not it's most likely somewhere else, relay, ign module etc...
Old 09-06-2010, 03:50 PM
pococj's Avatar
pococj
pococj is offline
Received 1,211 Likes on 461 Posts
Ride it! Not sure how many relays the '08 models have. The '07 has 2 of 'em. One is the Starter Relay, and the other is the System Relay. System Relay provides the juice to the good stuff that allows the bike to run.
Here's some part numbers for the relays:
OEM was an Omron 2165A21A
NAPA is AR614
ABC Auto parts is STD RY302. It was listed as a '03 GMC Envoy part.
Old 09-07-2010, 10:04 AM
sooie's Avatar
sooie
sooie is offline
did i say it sounds like a shot gun when it's doing this and fire/flame shots out of the pipes. then runs the poow shot gun then runs and so on
Old 09-07-2010, 08:50 PM
sooie's Avatar
sooie
sooie is offline
got the bike off the table and went for a ride.ran really good until it got good and hot (hwy for 5 miles) then it all started again POOW shot gun blast out the exhaust we made it home but was backfiring out the exhaust every time you load the engine
Old 09-07-2010, 08:53 PM
sooie's Avatar
sooie
sooie is offline
sorry it looks like im trying to hyjack this thread
i'm just at a lose at what to do here
Old 09-08-2010, 06:45 AM
WRAITH's Avatar
WRAITH
WRAITH is offline
Sooie,the first thing to get is a service manual. 2nd is a good multi-meter and a heat gun. Check the crank position sensor cold, then hot(heat gun).
Old 02-10-2014, 12:12 PM
bgtyma's Avatar
bgtyma
bgtyma is offline
Stage II
Default bike shuts off
I was told by the Harley dealer here in southern cali that is the circuit breaker by the battery, they replaced it last yr and for a year no problems and now its doing it again I replaced it this weekend and it shut down twice yesterday so I am wondering if this really the problem, can anyone off any suggestions
Quick Reply: Bike shuts off while riding!!!! WTF?
