Removal of Front Fender on a Forty-Eight
Old 09-06-2010, 05:01 PM
blastonerski's Avatar
blastonerski
blastonerski is offline
Default Removal of Front Fender on a Forty-Eight
Hello, do you know if I have to remove the fork brace if I remove the front fender on a Forty-Eight?
Old 09-06-2010, 05:16 PM
streetfighter06's Avatar
streetfighter06
streetfighter06 is offline
Man, front-end wobble blows. I would think it's even worse with a wide-glide front end. If you remove the fender, I would keep the brace. It's just nuts and bolts - remember that!
Old 09-06-2010, 05:26 PM
Guest
Guest
Posts: n/a
No, you do not have to remove the brace. It was designed that way for that very reason.
Old 09-06-2010, 05:42 PM
blastonerski
Thanks streetfighter06 and tekdiver500ft! I would like to have it w/o the brace if i remove the fender. Is it because the Forty-Eight's have a fat tire up front that's why they added the fork brace?
Old 09-06-2010, 06:00 PM
Guest
Guest
Posts: n/a
You really want the brace. It doesn't look bad, and the handling is tons better with it on.
Old 09-08-2010, 06:11 PM
JPL17's Avatar
JPL17
JPL17 is offline
I want to do the same thing--remove front fender but everyone says leave the brace on. Guess it's good advice. Now the back fender--I want to chop it but have no idea how to go about it. Have to look into that.
Old 06-26-2011, 05:49 PM
smoen81's Avatar
smoen81
smoen81 is offline
I've searched the forum and have come up with no luck. This site has a ton of information on it and I'm looking for some advice from someone more knowledgeable. I am very glad I stumbled upon this forum/community. I have the 2010 Sportster service manual and it does not list how to remove the front fender on my 48. It only shows other XL models and XR models. I assume, I just have to remove the brace (4 bolts) then remove the fender from the brace (4 star bolts) then replace the brace. Can anyone let me know if I'm missing a step or anything I should look out for. Thanks a ton.
Old 06-26-2011, 08:14 PM
UFOtestpilot's Avatar
UFOtestpilot
UFOtestpilot is offline
18-22 ft lbs when you put your front brace back on. The four bolts attaching the front brace can be removed just as you say. Then remove the four bolts attaching the fender to the brace.
Old 06-26-2011, 08:41 PM
smoen81's Avatar
smoen81
smoen81 is offline
Thanks!
Old 06-26-2011, 09:21 PM
rickthewelder's Avatar
rickthewelder
rickthewelder is offline
Heres mine with no fender, the brace stays.
RTW.
Attached Thumbnails Removal of Front Fender on a Forty-Eight-005.jpg   Removal of Front Fender on a Forty-Eight-001.jpg
Mchad
2014+ Touring Models
30
12-16-2018 02:30 PM
crotchrocket
08-27-2015 10:51 AM
Boner1200N
04-05-2011 07:27 PM
Wally
02-18-2008 03:51 PM
hedgehogch53
09-18-2007 08:09 PM
Quick Reply: Removal of Front Fender on a Forty-Eight
