Mounting headlight where fender use to be?
has anyone tried this or does anyone have pictures? I came across this
http://www.speedsupplies.com/accesso...asp?item=42609
its basically a mount that mounts where your front fender use to be.
Def. different. I'm thinking that if it mounts to the lower tree then the tire may contact it eventually.
Check out where the headlight is on this one.
http://www.ledsledcustoms.com/bike.asp?id=72
Then I think mreed's suggestion of mounting it to a fork brace is likely your best bet. Now of course you're going to have to drill the fork brace, but you won't have to drill into anything on your bike.
If drilling is causing a headache because either you don't have tools or you aren't mechanically savvy, just buy the brace and mark where you want the hole drilled - take it to a body shop. They'll probably do it for free or tell them you'll buy them pizza. At my old body shop we did little freebies like that all the time
