dakota digital gauge installed
#41
^^^ here, check out the instruction manual that comes with it. it's actually very simple. 1st time around you need to read the whole manual. then go back and read it a 2nd time and will find out how easy it is.
http://www.dakotadigital.com/pdf/mcl-3204.pdf
it has a gear position learning mode and will learn what gear you're in - after setting it up or programming it to learn - based on speed and rpm. it then calculates the gear ratios, thus knows which gear you're in. see below for the exact instructions.
as for the "shift indicator", what that is is a programmable "rev limiter" if you will. you can set it for any rpm from 1000 to 7000 in 500 increments. i have mine set at 4000 rpm now so when you hit that "limiter" or "shift indicator", then the tach blinks until you shift to the next gear. i'm still breaking in my bike so i have my rev limit set at 4000 and shifting always at that limit when it blinks. you can rev over that of course but the tach will stop and blink at the set limit.
here's the programming section for the gear indicator from the manual. looks slightly complicated at first but is actually very simple. i did my gear run through on a residential street and no more than 35mph through 5th gear.
gEAr Gear Indicator setup
This gauge has a single digit display for gear position. The gauge can learn the gear ratios based on speed and rpm so
no sensors are needed, just what you’ve already connected. It will work with 4, 5, 6, or 7 speed transmissions. To program
the gear positions, begin at a section of road where you can gradually shift through all of the gears. Press and hold the switch
while turning the key on and starting the engine. Once the engine is running, release the switch.
· Press and release the switch until “gEAr” is displayed, press and hold the switch until “ - “ is displayed.
· The display will show “off” or “Learn”. Press and release the switch until “Learn” is displayed, then press and hold the switch.
· The message will show “LO TCH” if the engine rpm is below 1500, or “LO SPD” if the vehicle speed is below 5 MPH.
· Begin driving in 1st gear. The display should show GEAR 1 and the “1” should be flashing. Drive at a steady speed until the “1”
stops flashing, it should only take about 20 seconds if the speed and RPMs are steady.
Optional: If the gear does not stop flashing you can manually override and jump to the next gear by pressing and
releasing the switch to store the gear position quicker.
· Shift to 2nd gear and drive at a steady speed. The display will change to a flashing “2”.
· Wait until the “2” stops flashing. Shift to the next gear and a “3” should start flashing.
Optional: If the gears do not stop flashing you can manually override and jump to the next gear by pressing and
· Repeat this through each gear. When you are done, come to a complete stop or press and hold the switch until the display
shows “SETvP” and then release it.
· Turn the key off and then on again to restart the gauges in normal operation, verify the gear position by riding through each
gear and seeing if positions agree.
#42
1 Post
I am getting ready to order the Dakota digital unit from phat performance. I was looking on their site saw this unit for a Big Dog. It looks really nice and is a little over $100 cheaper, unit is also by Dakota digital, looks like it has all the same functions too. what is a Big Dog?
http://www.phatperformanceparts.com/...r_p/bd-140.htm
Jerry
Jerry
#43
Jerry
Jerry
http://www.bigdogmotorcycles.com/
#44
Jerry
Jerry
#47
#49
#50
Ironmofo, love the gauge, am about to order one also!
quick question on the HD Fuel gauge, did you install it yourself or get the dealer to do it? i purchased one myself and i am wondering if should bother getting my hands dirty or just wait for the next service and get the dealer to install?
