Nighster Fender Slam
Old 10-13-2010, 06:52 PM
Slackster's Avatar
Slackster
Slackster is offline
Default Nighster Fender Slam
Ok I'm at it again. It's about the same time every year I start getting active again with these threads.
I already know some of you may be slightly dissappointed for tossing the springer and stripping the green paint, but I got my reasons.
I started and completed a strut project today. The key was to use my factory spring shocks while keeping the fender slammed. The best way for this is to just put the fender in motion with the swingarm.
It started off with the two flat strips of steel, yeah i was also making a new seat hinge, but anyways the strips of steel with the following specs: width -1 1/2" L - 14" 3/16" thick ( Strong!)
There was a bit of trial and error bending action going on here. there was a ton of grinding. it was a challenge trying to make matching pieces with identical end points. Now that i'm writing this I realize I could have just held both pieces on the grinder sandwhiched together at the same time. Damn It!
I meant to mount the strut on the outside, but at one point durring mockup one of the struts swang loose to the bottom, and as I lifted it baack up into position I accidently ran it inside the fender well and discovered it looked som much cleaner, so I kept it like that.
Than they kinda looked bulky and plain so I got crazy with the drill press.
Also to Add yesterday I mounted the headlight nice and low on the bottom tree, and yes I went to the 48 Tank. still much to do. gotta break it all down soon and get the new paint job, and a few parts to powder coat like the trees, struts, light mount etc..
Old 10-13-2010, 07:01 PM
mreed's Avatar
mreed
mreed is offline
I like it...and I wasn't a fan of the springer. Looking good.
Old 10-13-2010, 07:09 PM
Slackster's Avatar
Slackster
This is a fine example of what i'm talking about:
Old 10-13-2010, 07:13 PM
Aaron48's Avatar
Aaron48
Aaron48 is offline
Looks pretty kickass !! Nice job.
Old 10-13-2010, 10:50 PM
Dango's Avatar
Dango
Dango is offline
Wow. I've actually saved pics of your green one.
Old 10-14-2010, 02:36 AM
MarksBOB's Avatar
MarksBOB
MarksBOB is offline
lookin good slackster,
liked your springer, love the short fender look but i get sooo wet if it rains while out on the bob,
was keepin the fenders standard on the 48, but who knows !
Old 10-14-2010, 02:43 AM
Steeler's Avatar
Steeler
Steeler is offline
Default Howzit
looks great
Old 10-14-2010, 06:01 AM
michaelmartin's Avatar
michaelmartin
michaelmartin is offline
Looks great. My only word of advice is to be mindful of how you mount the struts to the fender as far as inside wheel clearance for the bolts. I first did it as a side mount and decided that the bolt heads were too close to the sidewall, so I moved the mounting holes to the top of the fender. But I also went with a flat trailer fender opposed to that tire hugger.
I'd love to know where and how you're mounting it to the swingarm towards center. I made a small L bracket and bolted it to the apex of the "U" on the inside and just wonder if there was a better way to go with it. Just because it makes taking the fender off with the wheel still on a pain in the ***.
Old 10-14-2010, 07:16 AM
XL50#674's Avatar
XL50#674
XL50#674 is offline
I alwasys liked you bike, but not a fan of green so to me the bike looks better now. I like the 48 tank on there.
Old 10-14-2010, 07:42 AM
bmxatv's Avatar
bmxatv
bmxatv is offline
looks good slack. i'm diggin the new look. i've seen that bike before on the net that you posted also, badass. i dig the sprung sporties with rigid mount solo seats better than strutted sporties with sprung seats personally. keep up posted.
Quick Reply: Nighster Fender Slam
