View Poll Results: A poll
Yes
40.30%
No
22.39%
I use black wire raps now.
34.33%
Mine fell of and I dont have one any longer.
2.99%
Voters: 67. You may not vote on this poll
Battery Cover Clips 06 Sportster
Old 09-10-2012, 05:08 AM
DOMAPOI's Avatar
DOMAPOI
DOMAPOI is offline
Use to have a problem with the cover opening up a lot. Then I noticed that they weren't lining up properly when I was closing it. Even though at a quick glance they looked like they were clipped properly they weren't. As a matter of fact, that is one of the reasons they changed the design from the ones I have, which are the old stock ones. Because the old ones were not lining up properly all the time, it would eventually cause them to break. You have to really get down close and make sure the cover is between the two halves of the clip and then they work fine. I don't like the new design at all (my son's bike has them).
  #42
Old 09-13-2012, 05:31 AM
rocketron's Avatar
rocketron
rocketron is offline
3rd Gear
i did the same used cable tie works a treet
  #43
Old 09-13-2012, 03:19 PM
Davemac122383's Avatar
Davemac122383
Davemac122383 is offline
I used zip ties and also drilled a hole in each of the plastic clips. I put a screw thru the battery cover and the clips and its been holding nice and tight. I just keep it zip tied as a precaution so I dont end up losing the cover.
  #44
Old 09-13-2012, 06:19 PM
HarleyScuba's Avatar
HarleyScuba
HarleyScuba is offline
Originally Posted by Thumper26
... Search the forum for "battery cover zip tie" and you should easily find the fix.
Or, look at post #32 in this thread.
  #45
Old 09-14-2012, 04:02 AM
Thumper26's Avatar
Thumper26
Thumper26 is offline
...Search the forum for "battery cover zip tie" and you should easily find the fix. In fact, there are a couple of fixes; one involves drilling a hole in the top of the cover for the zip tie, the other drills a hole in the clip. Both simply require a plastic zip tie or two...
My point was that there is more than one fix, therefore there is a choice. I was aware of your post and the solution you used is a good one, but not the only one, nor the one I used.
  #46
Old 05-26-2015, 01:56 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
Default resurrection!
I have finally drilled the zip tie slip holes. i had the clips replaced back in 2013 and all was fine. they recently started failing on every ride and had me riding around looking like i was holding in a poo.
i'd finally had enough and just did it. i removed the clips drilled through the middle of the front one and slightly toward the rear of the rear clip. added an extra hole to the cover. no problems since. cost... 10 minutes of my life. i already had all that crap in my garage for other projects.
Thanks for the photos.
  #47
Old 05-26-2015, 03:33 PM
Andy Knell's Avatar
Andy Knell
Andy Knell is offline
Funny how this keeps popping up. I almost lost mine today after almost a year free of problems. Turns out when I had it off this weekend, I routed the battery cable over the main fuse cable instead of under it which prevented it from seating properly. It's too fine a line between good and bad on that thing if you ask me.
falsealarm
11-02-2010 03:05 PM
Just Plain Cody
07-07-2010 06:15 PM
Micheletti
05-21-2009 10:37 PM
puyallup
11-04-2008 03:29 PM
cjm80
10-10-2008 05:38 PM
Quick Reply: Battery Cover Clips 06 Sportster
