Nightster Mirror flip
I have the same bike. I flipped mine with no problem. I still have the stock tank on. You will need to adjust the directionals, they pivot in the mounts. The only issue I had was them moving. You may need to add nuts on the bottom to go with the ones on top. Get extra Stainless star washers like the stock ones. Harley sells decorative nuts for the top as on the new models. Quick paint job to make new nuts washers match.
I have the same tank and flipped with no problem, just use the left on the right and visa -versa.
Install with the nut loose and swing the bars to full lock, tighten the nut with the mirror stem 1/4" from the tank then do the same on the other side, final adjustments can be done with the mirror head adjustment.
View is much better with one up but not great with two up.
