Last edit by: IB Advertising
DIY - Air Cleaner
• Step by Step Instructions
• Parts Needs
• Visual Guide
Read full discussion below
• Parts Needs
• Visual Guide
Small, cheap & easy do it yourself air cleaner (lots of pics)
#671
Because you have done it - how did you connect the copper to the hollow bolts? It looks like you were able to screw simply the soft copper onto the bolts.
Do you think a simple 90 degree elbow, pointing up, and two of the smaller filters would work - both vents dont have to be tied to the same vent do they? I have never seen it done with two seperate filters
Could you simply clamp the filters to the threads, and have them stick stright out? The diameters dont look like they would work.
Thanks.
Thanks.
#672
Questions about this,so I have to take off that black plate and then attached the mount right?? I ordered the breather kit,does it come with all the screws to mount it??my carb mount only came with 2 screws and the filter set just came with the wing nut screw for the cover..Is that black plate hard to take off ??
#673
Got the bracket and air filter for my 2005 Sportster. Do I also need carb mount bolts and breather bolts? I thought everything would come in the air bracket kit (ebay). I have sent the bracket back because none of the bolts worked, now I think all I needed out of the kit was the bracket. Can someone clear this up for me?
#674
#675
#676
#677
This looks great! Anyone who's tried this; do you know if you get any performance issues? By allowing more air into the engine, are you hurting the engine in any way? Does it diminish the engines life? Why doesn't stock maximize performance with in safety range of the engine? Sorry for the newbie questions.
#678
#679
Thanks everyone for contributing to such a great DIY project. I did it on mine so quickly and easily. It turned out awesome, threw some black paint on to match my all black '07 Nightster.
Quick question... or maybe poll. Of the several different types of ways to handle the breather system, what did most of you end up doing? Integrated breather/carb holder, breather bolts breathing to the atmosphere, running breather lines to rear/ground, or running tubes to a second filter/oil trap? Curious.
Currently I left the stock breather bolts exposed trying to figure out what I want, leaning mostly towards breather bolts.
#680
Personally, I didn't want the breather bolts since I couldn't control where
the gases went, so I did a contained system venting to a catch-can, then
to atmosphere. I have an Arlen Ness derby sucker intake modified to
vent gas as shown in the following pictures.
hope this helps,
T.
