Aluminum Polish
Old 03-01-2011, 03:47 PM
Canadian Castaway's Avatar
Canadian Castaway
Canadian Castaway is offline
Default Aluminum Polish
Looking for a good aluminum polish and cleaner for the aluminum parts on my wife's sporty, the heads, the primary...etc...
Candian Castaway
Old 03-01-2011, 04:15 PM
jerryw618's Avatar
jerryw618
jerryw618 is offline
hello there ive been using mothers mag and aluminum polish , it works great , i just cleaned all the winter gunk off my bike and its all nice and shiny now . Ive actually been using this stuff for about 3 years now . its my choice. couple of bucks at the auto parts store
Old 03-01-2011, 04:32 PM
Faast Ed's Avatar
Faast Ed
Faast Ed is offline
Candian Castaway
Napa usually has it, seen it at a few swap meets, even a few Dealerships.
Been using it for decades and a can lasts you about a decade. Great stuff.
It's like a string of cotton. You snip off an inch and wrap the rest back up.
Once your done applying it, you need two soft clean cloths. One to take the bulk off, then follow with the cleaner rag to polish it up.
If you ain't polished in a long time, you might have to hit it 2 - 3 times to give it that "chrome" look, but after that it's a one hit deal to shine it back up.
If your aluminum is real bad tarnished, hit it with some 1000 grit wet sand paper first, then follow with the Wizards. (Wet, the wet sand paper, don't do it dry).
Less than $15 per can (in my case, less than $15 per decade). LOL
Old 03-01-2011, 04:55 PM
83XLX's Avatar
83XLX
83XLX is offline
Mothers, Semicrome, and MAAS are 3 that come to mind.
Old 03-01-2011, 05:09 PM
Sportster Spence's Avatar
Sportster Spence
Sportster Spence is offline
'Belgom Alu' is the best aluminum polish I've ever used by a long way, nothing else even comes close!
Old 03-01-2011, 06:19 PM
Mike07FLHTC's Avatar
Mike07FLHTC
Mike07FLHTC is offline
semicrome +1
Old 03-01-2011, 06:22 PM
HarleyScuba's Avatar
HarleyScuba
HarleyScuba is offline
Nevr Dull
Sounds similiar to the Wizards stuff mentioned above. You pull off a wad of it and polish then wipe with a clean cloth:
http://www.amazon.com/George-Basch-N.../dp/B000VPBMCO
Luster Lace works pretty good on some parts:
http://www.amazon.com/Luster-Care-LU.../dp/B0012TWWAO
Old 03-01-2011, 06:32 PM
sr_smyth's Avatar
sr_smyth
sr_smyth is offline
Go to your nearest truck shop-ask for "Wicked" Polish
do not however, get it on the black wrinkle engine case unless you want to p*ss around with a toothbrush---name says it all-It's "Wicked"
hardheaded
Detailing
11
02-10-2017 08:41 PM
RK_2014
11-12-2013 12:33 PM
road_king_rob
06-11-2010 01:12 PM
SecondChance!!
06-03-2009 08:28 PM
Quick Reply: Aluminum Polish
