ViED/XiED Install - Lot's of Pics
Old 03-08-2011, 09:19 AM
XL50#674's Avatar
XL50#674
XL50#674 is offline
Nice review. I'm really thinking about getting them for my 1200C. Ir runs good now and have the AC and slip on's, but I don't think there is any type of fuel tuning on it and I got it used at a metric dealer so they did not know. I know there is no fuelpak or PC on it so unless it had a race tuner for it that I don't have it could ne stock tunning.
Old 03-08-2011, 05:17 PM
2011Iron883's Avatar
2011Iron883
2011Iron883 is offline
Originally Posted by bmxatv
pretty sure the dealer remaps are anywhere between 100-200$ depending on the dealer and my pcIII was only 225$ at the time i bought my bike (jus sayin) but point taken.
My local dealer was running a 'special' on the SE race tuner and dyno for $695. So that is what I based my 'tuing' number off of.
Old 03-08-2011, 05:51 PM
Osco's Avatar
Osco
Osco is offline
Account Deactivated
Cool My Online research says,,,
Originally Posted by northwoodsiron
thanks for the write up!!
im a noob with this stuff.....i have v&h pipes now ,iron 883, if i add these will i be able to add an intake as well w/o running to lean? i would still check my plugs but this would be great since funds are low and i want to put my intake on....
Info for EFI bikes only:::::::
FACTORY AFR Is EPA compliant at 14.7
An HD re-map will NOT change the AFR at cruise speeds(closed Loop),
only on acceleration.
They cannot do this or the EPA will have em for lunch with fines.
The X14ieD will let you run BOTH a Hi flow air filter AND ,,,,,
AND BAFFLED after market pipes like V&H and Rush or SE slip ons.
For Instance a SE Stage one Air breather and Rush slip ons with
UP TO 1.75" baffles.
2" baffles and up are getting close to straight pipe restriction levels and
Now you are entering the world of the Power commamders, Fuel pac's and
Master Tune systems.
The X14ieD does nothing for fuel tables,,
DO SOME READING before you mess with a Harley !!!!!!!!!!
Start here:
http://www.nightrider.com/parts/ied_faq.htm
then here:
Old 03-09-2011, 11:49 AM
icebite1's Avatar
icebite1
icebite1 is offline
IMO If i was spending that much i would go with a tuner that has auto tune feature ie: PCV,TTS,or TMax. with those you dont have to go back to the dealer every time you want to make mods/changes and thus save $/trip
Old 03-11-2011, 02:20 AM
Arrampico's Avatar
Arrampico
Arrampico is offline
Here is a photo documentary of a ViED or Xied install. After all of mreed’s awesome 'how to' posts, I thought this may help some of you folks. Before getting my ViED’s in, I really didn’t know what I was getting myself into until I started the install. I discovered that it was super easy but this may help some who are on the fence about buying them.
Here is my account of the install.
I went to the cooler and opened a St. Arnold’s Stout. I then opend the package and headed to the garage. There are two plug and play devices and the first one is located behind the battery cover here. Just pop it loose from the top and it swings down.
Behind the cover, you will need to fish out the O2 sensor wires with the quick connect plug here.
Now, take your ViED/XiED and plug it in between the factory plug, making sure they snap tight and you are done with the first one.
Next, Find the same O2 wire plug on the front of the bike here.
You will need to remove the factory wire clap and follow the same steps and you are done...not even a 1 beer install
Sweet, thanks man. Can i ask where you got your stuff at and P/N's?
Old 03-11-2011, 02:31 AM
Arrampico's Avatar
Arrampico
Default Xied / Vied difference?
Sorry, Noob question again...what is the difference between X14ied and Vied? I am about to do some googleresearch, but just thinking somebody here probably already knows.
Nevermind....i just found it on nightrider....V is variable. Looks like it has a little screw that allows you to adjust it. I don't think i want to mess with that do I?
I am just planning on adding aftermarker air cleaner. Nothing special.
Old 03-11-2011, 06:54 AM
2011Iron883
www.nightrider.com
Right, the ViED is an adjustable Xied. You can set your A/F ratio.
I am glad I got the ViED. I ran it at 14.3 with just the pipes and then kicked it up to 14.0 with the air cleaner. I am going to try that a while and then maybe try 13.8 (richer) and see. After a couple of weeks or so at 14.0 (this is what the XiED is set to), I am going to pull a plug and read it.
Old 03-11-2011, 07:19 AM
icebite1's Avatar
icebite1
icebite1 is offline
I am also going to try the VXieD on my sporty , that is if it ever stops snowing around here, 9 days till Spring
Old 03-11-2011, 09:57 AM
Osco's Avatar
Osco
Osco is offline
Account Deactivated
Cool Your answers,,,
Answers are on the web link,,FAQ page or product Info page:::::
X14ieD=14.0 AFR
XieD=== 13.8 AFR
all else being equal of course,,,,
Old 03-11-2011, 11:04 AM
2011Iron883
X14ieD=14.0 AFR
XieD=== 13.8 AFR
Yeah, sorry, I misquoted the XiED AF. I meant the X14ieD. Thanks Osco.
Quick Reply: ViED/XiED Install - Lot's of Pics
