Oil Change - 2003 883R Anniversary Edition
Old 03-15-2011, 02:20 PM
AC_HARLEY's Avatar
AC_HARLEY
AC_HARLEY is offline
Stage III
Default Oil Change - 2003 883R Anniversary Edition
Hey - All new to the forum, i just bought a 2003 883R anniversary edition with 17K on it - i wanted to know what is the best oil to put on a bike this age and millage.
Appreciate the help - its also has a 1200 conversion kit in it - if needed the info.
Old 03-15-2011, 03:37 PM
Osco's Avatar
Osco
Osco is offline
Account Deactivated
Most here like and use Mobil 1 Vtwin 20w-50w,,
easy to find,,,,Wally world,,Advanced auto parts to name a few
MAKE shure Its says V-Twin on the bottles !!
Get yerself the HD service book,,,trust me on this..
Old 03-15-2011, 04:04 PM
hig4s's Avatar
hig4s
hig4s is offline
That is what I use,, but technically V-twin is a misnomer, it is designed for air cooled bikes whether they are V-twins or not, and the Mobil 1 4T racing is designed for liquid cooled bikes. So the V-twin would be good for an air cooled inline 4, and 4T would be good for a V-Rod.
Old 03-16-2011, 08:44 AM
WVHogRider's Avatar
WVHogRider
WVHogRider is offline
Actually, most here tend to use the Mobil 1 15W50 that you can typically get from Wally world in a five quart jug for around $20-25, (when they have the big jug), and the HD oil filter. If Wally world doesn't have the big jug, just buy the quarts of 15W50. And use the Mobil 1 Gear oil in the primary.
Old 03-16-2011, 09:15 AM
jag1886's Avatar
jag1886
jag1886 is offline
I have always found it kinda funny that so many people can afford a Harley but want to save $12 on and oil change and put car oil in there bike instead of 20-50 VTwin Mobile ONE. The 15-50 will probably do the job but 20-50 Vtwin has a lot more additives to make certain it does the job.
Old 03-16-2011, 09:19 AM
AC_HARLEY's Avatar
AC_HARLEY
Stage III
Thanks for the help much appreciated - i have had bike for a number of years - glad to say its my first harley -- so i have a large learning curve.
Old 03-16-2011, 09:23 AM
guitarman023's Avatar
guitarman023
guitarman023 is offline
i use the stuff from the harley dealer, only because it makes my top end a LOT quieter, cams really make it sound like a sewing machine
Old 03-16-2011, 01:13 PM
hig4s's Avatar
hig4s
hig4s is offline
Actually the real problem with using auto oil, is some auto oil has too many additives, and/or the wrong type to be used with a wet clutch. So auto oil in a Harley engine shouldn't be an issue, but in the trans/clutch (specifically those oils that say "energy conserving" in the API circle on the back) of a Sportster may cause clutch slippage. Most motorcycle oils are designed to work in bikes that share engine and clutch oil.
Mad Mikey
01-02-2019 10:53 AM
Opsman
Oil Archive (no new posts)
05-01-2018 06:14 PM
SportsterRider85
VRSC Models
04-04-2011 07:54 PM
mclldavidson
01-15-2010 10:59 PM
gdaustin
12-06-2007 08:19 AM
Quick Reply: Oil Change - 2003 883R Anniversary Edition
