Add a 12volt power source to your sportster / nightster
Looks like you already had a connector hooked up for your tender, you could just plug your power outlet into that instead of adding another one from your fuse box. I use mine for the tender or I hook my power outlet into it and run the wire into my side bag with my phone charger to recharge it. It is already fused right off of the battery and you don't have to have the key on for it to have power.
Outstanding write-up. Nice little project.
With this, there's no key required and no hole cut into the fuse cover because an existing Battery Tender plug may be used. It is necessary to find a pocket to carry it in and I don't think it'll take an actual cigarette lighter.
You might consider drilling a hole and placing a rubber grommet to pass the wire through the fuse cover. You want to keep moisture out of those fuses as much as possible. Shrink tubing is the best thing since zip-ties. Not trying to be harsh, just my $.02. Definitely nice pics and write-up.
No doubt that's the easiest way to add 12 volt power. (by using existing tender lead)
But I posted this for those who might benefit in using a semi-permanent and safer way
(will not run down the battery once you turn your key OFF) to add a 12 volt outlet to your harley.
Remember that tender lead is constantly supplying power to whatever u plug into it.
Just a thought.
Just a thought.
But, there was a guy on another forum that turned one of his saddlebags into an icebox and filled it with his fav beer.
PS - really like your avatar!
