7" headlight on nightster
You may have to drill into the bottom horizontal member which holds the forks - can't remember what it is called. That is how most stock headlights are mounted, including C model sportsters.
I mounted a 7'' light on mine, but I had a stock bottom mount already. It just bolted right on. I really like the look a lot better than the bullet-shaped stock headlight that came on mine, not sure if it throws any more light though.
Not sure of the make of the light. I picked it up on Ebay for around $40. It was in bad shape. It was chrome but scratched and pitted pretty bad. Cleaned it up and painted it. As for mounting it, it came with a small block that bolts onto the triple tree. I already had a hole drilled in the triple tree from a previous install. If you don't have a hole in your triple tree, just remove your front wheel and fender and drill a hole to match your mounting block.
Also, I already sold the light last year, but do a search on Ebay and see what you can find. I'm sure there's something on there you will like.
For example: http://cgi.ebay.com/ebaymotors/s3d-U...item53e4018c75
1 Post
I bought a new 7" headlight from ebay for about $50, it was chrome but I painted it black. got mounting block from dennis Kirk for a few bucks. My Nightster mounts the 5" headlight to the fork. I had to bottom mount my 7" to triple tree, thus drilling 1/4" hole on the triple tree. I bought a Sylvannia bulb and it throws a wide bright light. The only pic I have is the one in my id.
Jerry
Jerry
Thanks again everyone for the pics. Havent had much luck on ebay keep getting outbid at the last miniute. May just have to do the buy it now thing because i am getting very impatient. My bike just looks stupid with the batwing and that tiny light. When i get one i will post some pics. PERK
