Lighted Mirror Install Questions
I installed a pair of the Harley-Davidson lighted mirrors yesterday on 08 S Sportster 1200 low. Every time I turned the ignition own it blows the 15 amp accessory fuse. Is this an indication of a short or is it an indication of the need for a bigger fuse?
Any help given will be appreciated.
It must be some type of ground issue. The "Y" harness works fine when installed, but everytime a mirror is connected the fuse blows. The was only one wire running from each morror and the instructions were not very clear about grounding. I did run a ground wire from each mirror, but must still have something wrong. Going through a lot of 15A fuses testing.
