Blue Smoke in traffic
Old 05-12-2011, 08:57 AM
joshamman's Avatar
joshamman
joshamman is offline
Stage III
Default Blue Smoke in traffic
Hi all,
I have an 07 Nightster that has a smoking problem.
If I sit idle in traffic for more than 2 minutes the bike gets super hot, and will start billowing blue smoke. It also makes an audible ticking sound when running.
I've had it to the HD dealership and they either couldn't reproduce it, or said it was nothing.
This doesn't seem normal to me. I have an RSD intake and tracker exhaust on it with a super tuner (all dealer installed).
Any advice/help would be greatly appreciated.
Old 05-12-2011, 09:24 AM
Cpitch's Avatar
Cpitch
Cpitch is offline
Originally Posted by joshamman
Hi all,
I too have a smoking problem..but it has nothing to do with my bike
In all seriousness, from what I understand about ALL internal combustion motors is, if there is blue smoke coming from your exhaust, you are probably burning some oil somewhere. I could totally be way off and wrong here..
Old 05-12-2011, 09:28 AM
Ajackson9687's Avatar
Ajackson9687
Ajackson9687 is offline
Usually its either rings or valve stem seals...valve stem seal leak will smoke when you start it mostly and rings smoke more while its running...so without looking further into it I'd say get some new rings and replace the valve stem seals while your in there just in case because they're super cheap.
Old 05-12-2011, 09:29 AM
Ajackson9687
and hows that tracker exhaust...best 2 into 1 I have ever seen in my life, does it run well though?
Old 05-12-2011, 10:06 AM
wahlumsurfer's Avatar
wahlumsurfer
wahlumsurfer is offline
This. If you're having blue tinted smoke you are burning oil.
Old 05-12-2011, 10:15 AM
jeffreydsilver's Avatar
jeffreydsilver
jeffreydsilver is offline
Default Blue Smoke
BLUE SMOKE IS OIL BURNING!
You shouldn't be burning ANY oil! Sounds like the engine is running WAY to hot. You might need to retune the air/fuel mixture properly. Smoke and an audible tick when running hot can only lead to no good (engine destruction)!
Old 05-12-2011, 10:26 AM
wahlumsurfer
Also, do you know how hot the engine has been getting?
I dunno if harley's suffer the same problem as most aluminum blocks, but if the temp climbed to high you may have warped the metal that may have broken the seal your rings would make.
Old 05-12-2011, 12:07 PM
RAL's Avatar
RAL
RAL is offline
Hi all,
Blue smoke is not to be ignored. Go to a competent mechanic. 07....how many miles on the machine? How long after the dealer did this work did this start?
RAL
Gary1
Engine Mechanical Topics
11
03-22-2018 03:24 PM
Ston
Shovelhead
12-13-2017 11:52 PM
RSDUDA
Shovelhead
09-09-2014 03:59 PM
SBates08
08-05-2014 01:06 PM
bikecop40
09-21-2006 08:37 AM
Quick Reply: Blue Smoke in traffic
