seafoam-ing engine
Well I don't have a carb but I have used it in my EFI...came recommended from a friend that has a carbed bike...a Mikuni 45 I think.
If your intent is to clean the carb, spraying into the carb throat isn't going to do much, as it will just get sucked through the throat and into the cylinder. That's great if your trying to remove carbon from the valves and head, but if it's the carb that needs cleaning, you need to pour it in the fuel tank.
I was just wondering. I believe my carbs are fine. They seem pretty clean. I was just more curious than wanting. lol.
Put seafoam into the near empty tank and then fill it up so you sort of know the ratio of gas to seafoam(it doesn't need to be an exact ratio) and also so that it gets well mixed up. The instructions say the entire full can is good for treating 8-24 gallons of gas. So in my 3.3 carbed sporty tank I put 1/3 of a can per full tank of gas and then run 3 tanks through.
My bike sat idle for over a year, and even though the tank/carb was cleaned very well it still was rough starting when cold. I'm on my 3rd tank of seafoam and the starting is getting easier and it runs noticeably smoother at idle.
You can suck an ounce or 2 of pure seafoam into a vacuum line, stall or shut it down and let it sit to soak the engine for valve carbon. And boy will you get a smoke screen from the exhaust when you fire it up, plus you probably kill any O2 sensors as well. O2 Sensors being blasted by that smoke is the main reason why I only have used it mixed in with Gas, plus most people don't want to mess with taking off vacuum lines, if they even know where they are.
